Installing headlight bar
David from Maine
I am restoring my 1930 sedan and couldn't get the headlight bar installed because the fenders where "relaxed" and needed to be compressed down. I couldn't find a post that talked about this and I didn't have 2 friends available to lay on the fenders to push them down. After I got the bolt through the edge of the fender and hoop, I took a couple of ratchet straps and wrapped it around the fender hoops and the tire trays. Then I was able to ratchet the fenders into place and get the headlight bar bottom bolts into place. I reamed out the bolt holes first with a drill bit that was slightly larger than the bolt. Worked like a dream!
I had the same problem with my 29 Tudor. I loosened the bolts holding the fender brackets to the frame, bolted everything up loosely, then tightened all of the bolts. Whatever works.
You have to loosen the braces. The headlight bar is basically a part of them. It ties the two together and adds extra strength to itself and them. It is supposed to be a tight fit.
Same advice as above, also loosen or remove the bolts that holds the fender braces to the outer lip of the fender.
