I'm to the point of installing the glass in my 37 Pickup and not having much luck. I have the original regulators. I actually have 2 sets. I set has tabs on the piece the window set in. these tabs are supposed to slide in the side felt pcs. the other set does not have the tabs.
I have new felt installed, the regulator with the tabs installed and cut a template out of cardboard to act as the glass. I figured out how to slide the glass in the door, front of glass down and rotate it to get it in the track. Problem is I can't figure out where the glass needs to be secured in the channel. Should the center of the glass be in the center of the glide channel?? Any help is appreciated.
