To clean the bottom of the rubber, use sandpaper disc that is the roughest you can get and scuff them well. It removes the release agent that is used in the molding process. Glue does not stick well to painted surfaces, and if you sandblast the steel boards, that is the best way as you get a lot of "tooth" for the glue to stick to on both the rubber and the steel. When you start to apply the glue, do it in 2 to 3 inch strips at a time. I have used masking tape to control the glue on both the rubber and the steel in 2 inch strips. Take your time and do a strip each day, allowing time for the glue to set up properly. FOLLOW THE GLUE INSTRUCTIONS. If you start at the edge where the lip is, it helps to get everything to come out properly. The last thing you do is the ends of the boards. You will have to trim them. I used c-clamps to hold the end pieces in place after I put the glue on. DON'T RUSH and it will come out fine.
