Installing a synchro Ford trans in an A
Have given up on using the 4-cylinder transmission. Going the F150 route. Lot more expensive but it's available in a "kit" that will bolt right in.
Bill
Bill Lee: saw this post today and thought i would add to it: check out my post on Clings v8 adapter: you must use a v8 clam shell and rear trans mount for the 4 stud hookup: i still have my stock pedals: you will need to shave your flywheel and use a v8 plate and disc: everything goes together smooth: hope this helps: skip
I know its your car but why go thru all the bother when Mitchel offers a synchronizer transmission for the model A. At the end of the day you will find cost to be the same. I have 2.
Have a Cling`s adapter to a 39 Ford trans. to my Model A pick up,work sgreat.Been driving it that way for four years,love it,makes driving it easy,life easy
You'll notice that the MAC's Bell housing comes with the Clutch/ brake pedal shaft already installed (item #14) which looks a lot simpler than the other kits?
With a Mitchell costing 2k how can you say the cost is comparable to the v8 ******? The Clings kit is 500 a sound v8 ****** will not cost $1500.
