What color?Put a Tutu on it.
Put a Tutu on it.
Does not have to be tight but should just slip in without hammering in.Ha HA. so cute
In determining the size cotter pin, Should the cotter pin fit pretty tight into the hole, requiring a gentle tap to push thru.
Buy a '33-'34 chassis parts catalogue reprint as all of the original size cotter pins are listed with each application. There's no need to guess when the specific information is readily available.
Some of the nastiest cuts I've had coming out from under a car have been from a cotter pin ripping my knuckles. Set the legs in a position that allows straightening for removal at a future time, while pointing those dagger sharp tips toward the nut rather than where your knuckles will find them.
