Installing a 6 volt electric fan on A model
The coolant flow is not the only thing to measure. Sometimes the radiator fins lose the ability to dissipate the heat. The contact between the fins and the tubes could be bad. If the timing and mixture is correct, and the water flow is good, the problem is likely the radiator. John
This is often missed when dealing with old radiators.
