Installing 1953 f100 horn button
Harls53
New member
Hello, I have put the horn assembly together and tested it. Instructions for horn button removal is to push horn button down and turn counter clockwise. So I assumed putting it on would be to push down and turn clockwise. Clockwise nor counter clockwise is working. The clip in the horn assembly, 2 of the three prongs ( I think that's what they are called) squeeze inwards so when u turn the horn button it seems that one of the prongs won't squeeze in. Like the button is being turned the wrong way. I hope I have made since in my description for some greatly appreciated help.
Thank you
The prongs need to be aligned with the starting points for the grooves they fit into in the horn button. If you get the two loop-like prongs hooked in their grooves, then apply pressure towards the 3rd, it will usually slip right down, then turn to lock.
