Purdy Swoft
You won't have problems with the water neck if you only use black silicon gasket maker insist of the usual water neck gasket. I leave the gasket out and just use black RTV silicon instead of the gasket. Never had a problem breaking the water neck this way
I did mostly the same on the last two engines that I did . The only difference was that I used clear silicone sealer instead of black. I figured if any silicone squeezed out it would be easier to clean or wouldn't be as noticeable . No leaks or problems with either in over 12 years .
