Ramblin Reck
Bought a third brake light from Summit Racing, the kind that attaches to the license plate. Of course no instructions came with it, not even what the Red, White and Black wires are for. One connects to Brake Light, another connects to Turn Signal and the third is ?????? I have asked Summit but it being Memorial Day, it might be Tuesday before I get an answer.
My 1939 Ford is 12Volt Positive Ground. Me thinks that if I attach the stop light wire to one rear stop light wire, I should be in business assuming the bezel that it is in is grounded. Maybe one wire is ground, I am not sure but if it is then that wire should be grounded. Not concerned with Turn Signals as I don't have turn signals installed.
I was thinking about using the Self stripping Quick Connectors to attach to the stop light wire, BUT that wire is cloth insulated not PVC insulated like on the 3rd Brake Light. Not sure how or even if that type of connector would work on 1930's cloth insulated wires. Any thoughts or ideas will be appreciated. Thanks!
