Install drive shaft with original ******
Convert the back of the transmission to open driveline (or change transmission) and
use one of the kits available to convert the rear end to open DL.
A cross spring rear end converted to open DL requires a very stout fabricated wish bone or super stout radius rods mounted to the frame or an additional crossmember
with the anchor points directly under the front U-joint.
The radius rod/wishbone kits available are ok for street use but will not stand a lot of abuse.
Remember that the torque tube is the connection between the rear drive wheels and the frame of the car through the ****** to the engine and then frame. Without the additional parts that Pete speaks of, the rear axle housing would try to twist off the springs.
