J and M Machine
These pictures I am posting represent an interesting aspect of Babbitted bearings versus inserts.
This engine was done by another shop and though the babbitt work was Ok. The dirt impregnation from assembly and running tells another tale.
This engine has 1200 miles on it, reason it came to us is customer wants to put stroker crank in it.
It's interesting since there's always two sides to the arguement of insert versus babbitted bearings.
These pictures show how well babbitt is able to "Digest" the dirt in the engine and still perform with a bearing surface of sorts.
The debris is glass beads with a mixture of iron and brass.
Naturally this is worst case senario but even still the babbitt survived.
I couldn't say that for inserts or the crank in same situation.
