In need advice regarding the removal of the input shaft bearing on my t87 Transmission. The bearing practically rests on the drive gear and there is little room to get a puller or an arbor suppert under the bearing to press or pull it off as instructed in the ford F series truck manual. I am considering placing the shaft back in the case with the assembly supported only by the snap ring when pressing it off but I am concerned that it will - well, snap. Any suggestions or experience here will help. I can't afford to damage the shaft. TIA, Carl
