I need an inner tube for a 4.75/5.0 x 20 bias-ply tire. Is it possible to use a 4.10/4.50 motorcycle inner tube? Anyone have any experience with this?
not all that long ago i was on a long solo bicycle tour and had completely destroyed the tube on one of my tires. i had no replacement and it was not a candidate for a patch, so i cut the tube on both sides of the tear, threw that piece away, and tied the two ends together. of course this turned the approximately 27" tube into about a 20" tube with a big knot in it. but tubes stretch.... i pumped 60 PSI in it and rode twenty miles to the next town with a slight "hitch in my get-a-long" the whole way.
As the subject wanders...
Long, long ago, just before dawn on a rainy Sunday morning, this skinny young paperboy with full paper sacks stopped at a gas station to top off his brand new English 3 speed racing bike tires up to 60 PSI.
I asked the station attendant how i'd know when my tires were full.
He told me it was automatic, so I pumped and pumped and pumped...
Until my tire blew up in my face. That was the start of a very unpleasant day for this 12 year old.
Why? Why does AI warn against radial tubes?According to one discussion website, a radial tube is a better choice because of the thicker rubber. However GhatGPT warns against it.
I got the tubes (2 for $40) and installed one. They seem about the same weight as the old one and don't think there is any difference between bias-ply and radial tubes. The only issue I had was the size of the valve stem. I solved the small diameter/large hole problem with a rubber plumbing washer in the hole squeezed between two 9/16" washers. Since the whole stem is threaded and nuts were supplied the valve stem is solidly locked in place. The stem only just protruded through the felloe (inner rim) so I screwed on a valve extender. I now have a spare tube which will also fit my 1926 Chevy's 21" tires. I know it's not a Ford but I added some pictures. I had to find and use my split rim tire tool to dismount and mount the tire like you do on a Model T. The car is a 1929 Willys Whippet that I completely restored. With the valve extension I think it looks good.
