inner axle shaft seals ??
Reddy
Help,
I'm going to rebuild my model a rearend and I'm getting the bearing and all for the job. But I can find how the seal will mount on the inner axles or the bells ?
Is it installed before the bearing race is installed ???
Mike
You want to install the seals after you have done your preload setup. The big seal goes in the hubs the small (same as drive shaft seal) goes in the tubes and needs to tapped into place and seated.
You will need the special tool that is sold by most model A vendors to install the inner axle seals. As said the inner seals should be the last thing. Set up the differential with old seals still in place.
Thanks to all,
I was thinking the inner seal was to be installed by the inner bearing race, but I see it is installed in the inside the axle housing on the outer side of the housing.
Mike
I use a socket (size of the seal) & a wooden closet rod (hang clothes on)to drive them in . ive done 3 this way with no problems . I make sure all is lined up & then tap / check ... tap / check until they are driven home .............. steve
