steve fritz
I just got my 54 Mercury up and running this week. I had some problems to begin with and want to get some opinions from guys who have recently put together a y-block. I found that the intial recommended timing of 4-6 degrees is way too little. The engine would barely run at that setting. I thought I had other problems because of this. I mean the car would barely pull itself from a standing start. Lots of popping off, backfire through the carb and no power whatsoever. Finally , I bumped the timing as far forward as I could, with the vacuum advance just about touching the back of the intake. Now it runs decent, has good pick up and just sounds better. I have had the distributor in and out several time, thinking I was off a cog or two. But not so, my rotor points right at number one plug wire on the cap. Any ideas as to why this initial timing has to be set so high???
I would say it's probably around 15 degrees or so, but thats where it runs decent.
I am also thinking of pulling the distributor again, and rotating it back, so I have more room yet to advance the timing even more. Right now it is sitting with the vac advance rubbing against the back of the intake, so I cant advance it any more like it is. Someone said the timing marks on the front pulley may have slipped on the pulley???? I don't understand how that could have happened, anybody had that experience???
This is the 256 V8 Mercury engine, it has the stock distributor and vac advance with original 54 Merc carb.
Any thoughts or ideas would be appreciated. Thanks!
Steve
Steve
