JeffB2
Dave D,did you use this? http://www.jalopyjournal.com/forum/...d-seel-great-sound-dampening-material.711889/ I did going on three years ago on the roof of my '54 Ford sedan it is still holding with no issues and you don't know hot in Florida compared to Phoenix summers with 110 + degree days,you cannot put your hand on the roof for more than a few seconds when it's that hot unless you want to check into a burn unit.I did prep mine by cleaning it thoroughly wiping it down with Brake-Kleen and applying a coat of Rustoleum aluminum before putting on the product.There is a sealing tape for the seams I reference to later in this link and pictures of it installed. It also helped to dampen the sound of the electric fuel pump mounted by the tank.
