At the front of the torque tube, behind the speedometer drive gear, there is a roller bearing and the bearing sleeve and a seal. The seal seems to be held in place by the bearing sleeve.
I need to change the seal. What method do you use to remove the seal and the bearing sleeve?
I appreciate your suggestions.
Thanks,
Steve
Thanks,
Steve
