Has anyone ever installed electronic ignition on a Model A? Are there pro and cons.
Thank You
Tom, this is a controversial topic simply because many folks believe what seems believable to them in this regard. FWIW, I used to be a dealer for one of the Model-A electronic ignition companies, and I have warrantied more than just a few units. Most will always agree that when they work, -they typically work well. When they do not, then they are a great cause of stress.
The background on these is they were popular a couple of decades ago when original style Model-A ignition points and distributor cams were very poor quality coming from off-shore manufacturing. Today, Bill & Tony Stipe offer a very high quality distributor cam that has some added dwell time to increase coil saturation. Top quality Model-A style points & a burn-proof condensers are now carried by most vendors, so they provide trouble-free operation for many miles. When the points do become oxidized, they are easily burnished with a fine piece of sandpaper and you are quickly able to travel on to your destination.
One other misconception that comes from those defending the electronic triggered ignition system is many believe the electronic ignition produces a hotter spark. Unfortunately, that is incorrect. The coil itself is what produces the voltage level (intensity) of the spark. Neither the Kettering-style points nor the electronic triggered system affect the spark intensity outside of saturation time. More often than not at the RPMs of the engine, there is plenty of time for the coil to fully saturate providing the best level of spark it can.
My advice is spend your money on properly rebuilding a distributer just like Ford designed it, and if you feel you need an extra piece of mind, carry an extra condenser and coil under the seat. If you decide to use the electronic set-up, make sure you carry an extra module (pricey) and a bottle of Tylenol to ease the pain of your headache when the electronic system fails.
