OK hey feeeek ;;; something to look at, a list if you will. don't know what you people use for fuel there, but here we are forced to use a blind of alcohol/gas...we call it "corngas" and it is the cause of a lot of trouble with the flathead,,,eats soft stuff. like the fuel hose, the diaphragm in the fuel pump, ect... so the best place to get the pickup hose is; Robert Shewman his e-mail is
gadgiteer@aol.com... he is also a "barner"
#2. Change or replace the distributor, the old divingbell or football it something called is a good unit BUT, difficult at best, to work on,.. and with your adaptor plate, one more can of worms ?? Best is the "crab " or pancake sometime called, two ways to go, one replace a two bolt timing cover/with a one piece seal on the crank,... or a three bolt adaptor plate, on for the two bolt crab.dist... it also has better advance curve than the divingbell. dist.... but a lot of work for something thats running now...right.
#3. Headers, the stock exhaust system, at best is a choke down system ( boy am I going to hear about that statement ) they RUN and sound so much better with straight pipes small dia. 1-1/4 or 1-1/2 inch all the way out back ....
#4. Your imaginary air filter, is just that. best get an original Ford oil bath, an have the top/cover chrome, hey I like chrome better than most, I have stuff in the chrome shop all the time.
get on e-bay ...google flathead, ford ...you will find a 2,000 plus ford parts for bid, I have several bid going now, better go check some now... .... good luck and keep asking questions, and we like pictures ...as walt, said lets see the truck, .....OLD....BILL
