Bob Grieb
This must be a Newbie issue but I am frustrated over my ability to get the ignition system to function.
I have a six volt system that I have been working on for over a week now and I have a problem getting six volts at the points when they are open.
I have replaced the points, plugs, condenser (twice), the distributer cap, plug wires, ignition switch. terminal box, and armored cable. The voltage reading at the points has been six volts but it is not consistant. At present I have no voltage when the ignition switch is closed and the points are open. I have checked and double checked the wiring terminations to the schematic and I cannot identify a problem.
Is there anything that I am missing or need to check??
I do get six at both terminals of the terminal box.
Thanks
Bob
Thanks
Bob
