Paul Bennett
Ok. I keep reading that the ignition switch properly controls just 'Coil and Gauges'. Radio, heater, elec wipers (if applicable) are accessories best placed on another switch.
Amungst you 'Extra-Switchers', what have you done, placement wise. Or is this just all talk, you simply add additional loads onto the coil or gauge terminals.
Cars with Overdrive and electric gas pumps could benefit from a relay without violating the primary ignition switch 'coil and gauge rule'. Well, coil, gauges, and relay coil rule.
At first I thought using a relay makes sense but not if one wants to play the radio without having juice run to the coil. Key off, coil off, mandatory, I'm sold but realize my answers are best done by a poll, hoping to cover the possibilities
