Ignition question
howie123
I am in the process of troubleshooting my ignition system due to a running rich condition. After setting the point gap and timing I check for spark when opening the points. I do get a spark at the points but I also hear a spark in the area of the coil or terminal box. I don't find any loose connections. I do not have the coil high tension lead in place. Where would this spark be occurring? Thanks. Howie
It's probably jumping from the secondary to one of the primary terminal,
you should have the coil wire about 1/4" from the head.
Bob
