Found info. that said if the ign. switch is left on for over 15 sec. it could damage the module.
Nope the car is still in storage, the gap on the module was so wide I could get 2 pieces of .030 plastic card between the shaft and module. Nothing is movable on the module plate so hope that's fine. I couldn't find any info. on replacing the Ignitor 2 module that mentioned the gap setting. I found the Help line no. and will call them to check it out. Thank you for helping me with problem, I can't bend over the hood much longer, old back don't like that. I'll keep in touch. Al
My instructions were very emphatic on the air gap being set correctly. Mine is 302 with Pertronix. Runs strong.
Now do you have an OEM DIST w/ IGN II module or do you have the complete FLAMETHROWER DIST ASSY?
50 Ford mine is all Pertronix, Flamethrower dist. with Ignitor 2 module. There is no adjustment inside the dist. to move the moduel closer to the trigger shaft. I'm hopeing that's the way it's supposed to be. Been running the car with no problems for 2 yrs. or more with same setup, don't know yet what happened yet. Al
I got my new module yesterday, called pertronix and talked to a service tech. He told me to run a ground wire from battery neg. to dist. housing with 12 volts on pos. side of coil and it should fire up. No spark I left the old module in for that test to see if it was good before changing it out. Had to quit because of weather, will try again tomorrow if storm has passed. 50ford the module on my Ignitor 2 has no slots in the mounting screw holes for adjusting the gap. The module mounts on a C shaped plate that mounts to a round plate in top of the dist. with no adjustment in either for setting gap. Al
