Ignition Points Part Number
Bruce/CT
Hi Aers,
Hoping to get my "A" out of a 9 year sleep. After replacing it's pop-up, I find that it only coughs but will not start. I suspect that the points are tarnished over due to age. Does NAPA sell points for the Model A engine? If so, does anyone have a part number?
Thanks,
Bruce/CT
Image Not Available
Contact Set (Points)
Product Line: Echlin Ignition
Per Car Qty.: 1
Compare ECH CS30Price
Unit
19.99
Each
Qty
Voltage Regulator
Per Car Qty.: 1
Compare ECH CU1This part can only be purchased from your local NAPA Auto Parts store.Distributor Condenser
Per Car Qty.: 1
Compare ECH FA5Price
Unit
7.99
Each
Qty
Distributor Rotor
Per Car Qty.: 1
Compare ECH FA3Price
Unit
11.49
Each
Qty
Ignition Coil
Product Line: Mileage Plus Electrical
Per Car Qty.: 1
Compare MPE IC7SBPrice
Unit
18.29
Each
Qty
Ignition Coil
Per Car Qty.: 1
Compare ECH IC7Price
Unit
44.99
Each
Qty
Ignition Coil Mounting Bracket
Per Car Qty.: 1
Compare ECH ICB15Price
Unit
7.49
Each
Qty
Generator Brush
Per Car Qty.: 1
Compare ECH F403Price
Unit
2.49
Each
Qty
Horn Relay
Per Car Qty.: 1
Compare ECH HR100Price
Unit
17.69
Each
Qty
All you need to do is clean the points that are in there. A few strokes with a points file, or with sandpaper will have it going in less time than changing points, and at no cost.
For points and condenser, I believe only specialists have B parts. They seem to be back in production, but I have not ordered or examined any new ones. For quite a while only NOS/NORS ones were around.
NAPA/Echlin and Standard dropped them a long time ago.
I hope someone here either proves me wrong and finds a good quality parts company making them or has discovered that the ones now being made are good quality!
I noticed that they were scarce and expensive a few years ago, and went hunting at Hershey. I discovered a bunch of dealers who had gas station type selections of elderly points with no catalogs and no idea what the parts in the dusty boxes fit, and a bit of rimmaging got me 5 or 6 B sets from a number of vendors very cheaply.
The look is distinctive enough to separate them from common Autolite types that are similar, and I was greatly aided by part numbers like FO-2!
