Anyone know if a 65 mustang coil uses 12 volt or is there a ballast resistor in circuit. I am looking for a ford coil that will work on 12 volt with no resistor
I would suggest the Bosch Blue ignition coil , no resistor needed and has a working resistance of 3-4 ohms.
We also sell a 3-4 ohms coil as well if you cant find a Bosch unit locally......
