dmaxweb Well-known member May 31, 2010 #1 I am using a simple (not pop-out) inginition cable. Is there a smaller inside diameter grommet available for where it passes through the terminal box?
Thom IV Senior Member May 31, 2010 #2 As a temporary meassure you could always wrap the ignition cable with wide tape and then put the grommet in place. Thom
Mike V. Florida Well-known member May 31, 2010 #3 dmaxweb said: I am using a simple (not pop-out) inginition cable. Is there a smaller inside diameter grommet available for where it passes through the terminal box? Click to expand... Have you thought of replacing your wire with this one; Looks stock and with the bare end, it attaches to any none pop out switch. (I have one on my car).
