A a guy Member Jun 5, 2015 #1 Need to remove ignition cable from distributor body. More than hand tight!! How do I loosen without marring cable? Should cable be screwed in far enough to make indent in lower body plate area here where condenser connects? Thanks for your help..
CarlG Well-known member Jun 5, 2015 #2 I have wrapped it with duct tape and used soft jaw vice grips. Probably a better way, but that's how I did it.
Jacksonlll Well-known member Jun 6, 2015 #5 It is very easy to tighten it too much and cause a short. Just hand tight is plenty.
