billfish
I seem to have another bad coil on my stock 51 8ba pos. ground Victoria. Engine seems to miss at cruising speed after a short run time, not at idle. A new Napa 6V Echlin (no resistor required) coil #904 corrected the problem for a while but it has returned. How hot should the coil get, it seems hot to the touch after a short run. It is properly connected with ign wire to - and +wire to dist.
