[FONT=Verdana,Arial,Helvetica]It's an old Anderson timer. Thought about replacing it but haven't... yet.
Sprayed brake cleaner at each "raised valve" through the spark plug holes today. Didn't seem to help any. They all went up and down but obviously no measurements were taken this way.
Also pulled the sediment bulb and disassembled that. Beautifully clean with nearly zero sediment on the screen. Bottom of the fuel tank is bright shiny galvanized although the exterior shows it is probably a replacement tank/not original issue. SO.. the fuel system is/has been clean from the beginning.
At this point I think I am leaning with those who feel it is timing or in the ignition somewhere. Work on that next.[/FONT]
