RandyMettler
I have dual 94's. My plastic snail synchometer vacuum readings are high. One is higher then the other. When adjusting the idle mixture screws, the snails readings do not change much, if at all. I pulled all 4 screws to check the condition of the end surfaces and they appear to be in good condition.
I also pulled the 94 bodies and set the throttle plates to close at the same time by adjusting the non-progressive linkage.
Is this a common problem with mixture screws?
Regards
Regards
