Shew01, thanks for posting back. I enjoy posting on these issues. It helps me retain the information I have learned on this forum and other sources:
Suggest you plug the wiper line, as suggested in one of the above posts. This will eliminate the vacuum port as an issue. The plug is a pipe thread and is available at hardware stores. Take the vacuum gauge for a match???
(Many carb issues often turn out to be electrical in nature i.e. weak spark for instance. We are assuming that your points are clean and set at ~.020 gap, and your timing is correct. Grounds are clean, bright and tight and so are all connections from the battery through the primary ignition and back to the battery + pos post. Battery is at sufficient charge and the generator / alternator is putting out ~7.2 volts at high idle)
There are several posts above that describe the procedure for setting the base idle. You can remove the malfunctioning throttle linkage at the carburetor throttle plate to set the base idle. Set the idle air adjustment screw to 1-1/2 turns open. Warm the car at idle for 15 minutes or so to reach op temperatures. Retard the spark and hook up your tach. Set the idle as low as you can, 350 - 400. Open and close the GAV and it should not have an effect. Gently turn idle air adjustment screw in all the way. The engine should stumble or may die. If it dies, reset to 1-1/2 open and restart. Test by opening to 3-1/2 - 4 turns. The engine should at least run poorer. If it does, set the adjustment in between. This likely will be close to 1-1/2 turns open, 1-1/4, 1-3/4 etc.
Advance the spark a few notches and check the tach. Hook up your throttle linkage. 500 - 550 will be alright. It is a bit high on a well sorted engine, but the stalling at a stop should be gone. If not, report back and we can proceed from there.
There is a very thorough article on the FordGarage that discusses the 'stalling at a stop' issue.
