Rich Largent
I'm the fellow who posted "mine won't start either" and thanks to so many of you taking the time to counsel this newbie Model A'r I got her running today. Seems as though it was gas problem and possibly fuel/air thing as it took flooring the accelerator to get it to light. Once lit it runs quite smoothly but does not have a steady idle. I haven't fooled with the idle air screw (currently 1-1/2 turns out from all in), only with the idle screw on the throttle shaft. Although it appears tight I see some gas seepage at start up around the throtle shaft. This disappears as the engine warms up. Any suggestions for fine tuning the idle?
