Identifying Shocks
mlp623
How do you identify a "new" shock that is sealed and doesn't require oil vs an original rebuild that should be topped off?
Can you pull a shock lever and post a photo of the cover, by the looks of your photo, the Patent # does not seem to match Pete's shocks.
Darryl
If I remember correctly aren't the shock bodies of Pete's shocks made of Brass?
Or maybe its another repro shock that is brass.
Darryl
Darryl
Here are a few more (not all the same shock). Looks like Pat# 108701. I only see made in the USA - not Chicago.
Matt
Matt,
Probably good news, according to the Restoration Guidelines and Judging Standards, you have the Second Style Ford Shock, February 1928 thru July 1928.
Patent # 1087017 is the original Houdaille Patent.
Darryl
Matt,
Partner # 1087017 is the original Houdaille Patent.
Darryl
Darryl
Thanks so much - I never thought to look in the judging standards. The motor is a Jan 28. Since those are not sealed, I can go ahead and top them all off and adjust them.
Matt
