Yes, the double reflection means it is safety plate laminated glass. You can hold something small up to the glass and look at an angle for a double reflection. For the side windows, look at the edge when the glass is rolled down, and observe is there is a line, which is the plastic center of the sandwich. As for tempered glass, Ford did not use tempered glass in the model A. It was either safety plate, or plate glass. All Model As had safety plate windshields from the factory, but I have restored several cars that came with plate glass windshields, installed some time between new and when I got the car.
