identifying model year
wbs
hello-i'm try to find model year of my car-i underdstand that the year made can be determined from the engine number-is there a table somewhere (if so, where?) that cross references year and engine number? by the way, my engine number as best ican see is 2763283 thank you
August 10, 1918. Model year is 1918. This particular model year ran from August 1917, until December 31, 1918. 1919 model year started January 1, 1919
The serial number list by month, day, and year is in "Model T Ford: The Car That Changed the World" by the late Bruce W. McCalley
The Lang's catalogue gives only the calendar years. Here are the calendar years and the model years together:
  • Calendar:Model.jpg
You will only know when the motor was built from that number -
The actual date of the vehicle is harder to identify
The motor might have been changed etc.
The only ones you know for sure from the serial number are from December 19, 1925 on. That's when they started numbering the frames. If the frame has the serial number you can go by that, even if the engine has been changed.
