Identifying a few parts
Al K.
Hi all, I am working on a 34 Pickup. In the purchase, there were several parts I do not recognize. Perhaps you could help. One looks like a spreader tube with some form of straps on it. The second looks like an air deflector, but does not span the gap between the front horns of the frame.
The last one, and I hope the pictures post in this same order, is a different question. I only have the lower radiator to grill brackets. Does anyone have a picture of the upper? I could probably fabricate a pair, but I have no idea how they look. Some dimensions would help too. Like overall length and offset.
Thanks, Al K.
34 truck but later 24 stud mtr. and possibly a 36 rad.with the big overhang on the rear side. Lot of mix and match. Dont even think the lower bracket is correct. Looks homemade?? ken ct.
The radiator is '33-'34, the splash apron and spreader bar are, as indicated above, for '33-'34 big trucks.
Thank you gentlemen. I had a feeling some were not for this.
Yes, the engine is out of my avatar, a Schramm / Fordair compressor. Whould be fun to get all 8 cylinders firing someday. I had it running as a compressor, but it needed attention to run right. I will wait after the engine build to tweek it.
Hi again, just wanted to ask again if anyone has a photo of the upper radiator braces?
Thanks, Al K.
Hi,
I'll just bounce this back to the top this once. Anyone have a picture or dimensions for the upper radiator brace for a 34 pickup?
Thanks, Al K.
I hope these help.
Gary.
