Hi again, Guys, well, DMSFRR was correct, I have been in for Repair at the VA Hosp. A triple bypass in Feb. then 2 of the graphs collapsed by May bringing 2 more surgeries, just got home Thursday. Thank you all for you posts about my
Y block questions. The engine is in my 37 Ford which I am going to sell. Trying to decide if I should swap the engine out or sell the car as is. Reason: most people seem to want a late model SBF or SBC drive train; this is a very strong running engine with 3 deuces and obviously has been worked up, cam ,etc. I would like to see that someone doing a vintage bird etc. have access to this engine. I found these numbers on the engine, casting- 57 V(?). L, ECK 6015, then 58D2K stamped. I hope that this will help. Kindest Regards to all, Rod
