coupe1942
I found this horn at a roadside thrift sale and was thinking of using it on my sidecar rig. I was thinking it probably was activated by squeezing a large rubber bulb on the end of it, but then I found a photo of someone who had a similar horn rigged up in a later model car than the brass era ones.
Can anyone identify what it may have been used on?
It comes apart at the end and is threaded there. It has a reed inside the tube. Blowing air into it has not produced anything, but when I unscrewed the end tube, I didn't find any blockage inside.
Is there an easy way to rig this up on a later Model A Ford for use and not just use a rubber bulb to honk it with?
