Identify a 57 engine?
Should have a spacer between the water pump and timing cover, have side of block stabilizer rod, rear sump oil pan, road draft tube out of rear of valley cover and maybe a tach drive distributor. Should also be ECZ-B intake and ECZ-G cylinder heads.
