identify 59 Flathead V-8
Thanks for the info Brian. I'm no expert, but going over some pics of articles I've saved, I would agree with you regarding the features you pointed out. From the few pics I have of my block, I have no markings cast into the bell hounding other than the number 4. At the moment, the block is wrapped in plastic, and I don't won't to remove it as I'm doing some reno work in my workshop.
Attached is the rebuild tag which shows it listed as a "C69T.A". Does the "T" mean truck? I do have the heavy duty oil pan with the oval shaped clean-out. Also, I thought I read somewhere that truck engines were factory relieved. Is this correct?
Here's a closeup of the cast marking in front of number 5 cylinder. Very hard to tell if the "6" was orginally a "5" and was ground down to make it look like a "6", but that would seem like a stretch.
When I look at it closely, it seems that you can almost makes out the number "5" underneath the number "6", especially the vertical and horizontal straight portions of the number 5.
I've marked up the pic where you could possibly make out a number "5". Would this have been at the factory on the fly?
Ziggster,
I believe you are right,,,,that 6 doesn’t hardly look right.
When I enlarge the pic,,,,it definitely looks like a 5 next to the 9.
And the 5 looks like the correct font. What do you think ?
A lot can happen to these engines in 70 or 80 years .
It’s still an awesome engine,,,you are gonna be happy with it.
Tommy
