Anymore thoughts on serial number making this officially a 38? To me when you zoom it looks like another * at the end/ after the 3. Does this make sense with the other options it has that insinuate that it is a 39? Maybe a Late year 38?
I purchased this thinking the engine was seized, stopped at the father in-laws to show it off as he is a Die Hard FORD GUY.. He pulled the dip stick, noticed it was 3/4 full, dirty but with no signs of water. "Are you sure this engine is seized?" he said. Sure enough I slow steady pressure to the crank that came with and it broke free. Ever since i have slowly been tinkering trying to get in running.. Had the starter rebuilt from a local Auto electric shop, new 6 V battery, New start button, Plugs and cleaned up a bit of wiring. Have voltage throughout the start circuit and Voltage to the coil, but do not have spark.. Just going to confirm Primary and secondary coil readings then maybe thinking of sending the distributor to BUBBA.
Any other suggestions?
Attached are some more pics of the options on this maybe 38 or 39..
