Where do you find a 380 g piston?? And would 20 or 30 grams make a difference when you drilled your balance holes??
Hi Ron, let me answer the second part of your question first. There really is no way to tell??
Depending on the tolerances the shaft was balanced to from "day-one" by adding a 20 or 30 gram piston it could be worse or it may actually be better. This is something we don't know until the weights are made and you get an initial reading on the crank!
Having said that I can say with all honesty you will not "feel" any vibration from the piston differences you show above. But they would have to be consistent with all 8 pistons. If you wanted to verify this info a simple call to Federal-Mogul would give you an answer. It's always been their contention that if all 8 pistons were changed there'd be no issue! I tend to agree, to a point.
I just want to stipulate here I am NOT recommending not balancing ANY rebuilt engine's, doing this for a living we could NEVER run the risk of possibly having a vibration issue! We actually run 2 balancers here, sometimes together. We have a Stewart-Warner (hard-bearing deal) and a newer style CWT. ALL strokers regardless of mfr get done on the CWT (there are no hard brgs, shaft runs on Teflon) it makes the job much easier and it is much faster than the Warner! Both are very accurate however.
Now for the first part of your question, I have here with me now a piston that is in the photo below. It is a factory std bore Flathead, this particular one weighs 370 grams, the pin weighs 130, and it is part#EAC-6110-A, it is a FOMOCO piece! I have some "Nylen" stock replacements here, .030"/.060" over, that weigh 395 grams.
Thanks, Gary in N.Y.
P.S. One other item I missed about balancing, the shaft actually gets balanced on each end (obviously), this explains the holes in the front and rear c'weights. but it is also done on another "plane" (sort of like a long straight perfectly round 6.000" shaft), normally speaking and under ideal conditions if you remove X amount of weight from the front c'weight you would remove the identical amount 180* from the rear. You will find this consistent on almost all factory crankshafts, the problem gets way out in left field when you order these new stroker shafts. One reason we like the Eagle FH cranks, they balance up much better and much easier! (Here's the piston photo)
