... Target 450 rpm ...
David Renner
Schoenen Nachmittag,
this is, where I would like to pose my question, as I do not know how much the oil pump still delivers at this halved low rotational speed.
Guten Morgen.
I used to think it was something to be proud of, having a very low, smooth idle.
But the downside is that the oil pump delivers very little oil at this time.
I don't think that's good when the engine is hot and you're stopped at a red traffic light.
I can see from the transparent return line that only very little oil is being delivered at idle.
I think you’ve made a logical error. The return line is an overflow line. It only passes oil if the pump is moving so much oil that the tubes feeding the bearings and the valve lifter bores can’t hold it all. I’m not at all surprised that you’re not seeing any oil in it when the engine is idling. You should not use this amount as a guide to how much oil is flowing overall.
The idle speed is a matter of personal preference. I have not found a factory RPM for idle speed.
