ID this "A" transmission
deadelvis2000
Fellas,
I inherited this transmission with a bunch of parts I purchased. Is it for a large A truck? Looks like my standard except for the lever to the right of the shifter. As always...thanks in advance.
I believe the 28 early 29s had a E brake lever in front of the shifter. Thats one for a car, no truck. Iceman
I agree with Don Turley. I would think that a photo from the other side would show that the clutch release lever and shaft has a small retaining pin and the lever is slid over a woodruff key, as is the throw out bearing fork.
Tom Endy
Don, would that transmission have a multi disk clutch, or had they been obsoleted by then?
This is a single plate clutch. The multiplate bellhousing has a cover which is wider than it is tall vs. this cover, which is taller than it is wide.
Also the release bearing is part of the clutch pack on the multiplate.
