ID a twin plug Flatty?
Shadetree, The carburetor in 51 Merc's picture appears to be tilted backward. Would this mean that it more likely was a boat engine than a plane engine?
The carb does appear to be tilted but another Barner says it’s the picture.
I can't see any advantage to either application. Interesting engines.
I believe it was KONG that offered a two plug per cyc. head, early 50's...and NASH had a 16 plug wire dist, and didn't Bubbna show use a 16 plug wire dist, a short wile back, and next to impossible to find parts for. ??? ....OLD....BILL
Lawson, Marine engines are water cooled.
Most cars are Indirect air cooled.(the heat transfer is via a radiator)
It's the terminology, Direct air cooling or indirect air cooling.
No one seems to know about the heads.
The cooling fins appear to run the wrong way.
Here in New Zealand there were twin plug heads made in the 50s or 60s by Ron Hogan, of which some survive today. I believe his son Garth may still have the patterns and may have produced some.
