The VIN number should be on the top of the bell portion just above the inspection port. Mac VanPelt's site has the numbers. It would be worth that if you get at least some good parts with it. If it is missing the top shifter housing & parts, has rusty gears, or has a crack or worn down thrust face in th case then that limits the value a good bit.
