Well it helps. Wow 25 cent fuse would have helped here.
Isn't there supposed to be a terminal block here somewhere?
Isn't that it on top of the head
Bob
Yeah, time to toss the wire out and start from scratch...
When I read something from Tom Wesenberg, I know I'm going to learn something. On behalf of all the Barners like myself, Thanks.The year I tought auto mechanics at the Vo-Tec one of the other teachers told the students to put a nail in the fuse box to find the short. Not to smart to burn up wires to find a short. It can be easily done using a flasher and compass. Replace the fuse with a flasher and light bulb, or resistor, then run the compass along the wire harness. The pulse of current will make the compass needle move. Once you go past the short, the current won't be flowing and the compass won't move.
Hi Tom,
For us electrically impaired folks could you post a picture of the 'flasher and light bulb'.
Thanks,
Mike
Hi Tom,
Thanks,
Mike
Thanks for the comments and suggestions!
Definitely going to incorporate a fuse.
On that note, I've got a lot of rewiring to do. Lots of shody electrical splicing done over the years. Plus going to add a second tail light, turn signals, and probably go 12v.
Since I need all new harnesses, I'm weighing the idea of a modern style wiring harness with a hidden but accessible muti-fuse block.
Anyone done it, or seen it done?
