felix37
I'm running a 39 81-T motor in my 37 sedan with a t-5 s-10 ****** (speed way bell housing)with modified stock pedals,GM 10 bolt rear end.Im considering changing to a 53 flathead.I understand the 53 motor does not have the same type of bell housing and my adapter kit will not work.what will I need to make this swap? and will I be able to use my current clutch linkage,etc. will I have to shorten my drive shaft? there is alot of what if's!! is the swap worth it or should I just beef up my existing 39 motor it is stock except for electronic ignition. Thanks Barners!! you always give good advice!
