i need help-with 33
T Bones
Three questions -after alum intake and heads are beaded and polished -how do you keep them from corroding? #2- where do I get head gaskets that will fit the expensive orig aluminum heads from water passage corrosion? #3- what kind of coolant or additive will stop the corrosion? Please help. regards T bones Thank you Ford Barn-Great Website
I use 'No-Roison' coolant additive to protect the heads in my '34. Good info at their excellent website here: > http://no-rosion.com/norosioncoolant.htm
I use Best Head Gasket # 507G as seen here: > http://www.bestgasket.com/pop_up_picture.asp?PartNumber=507G
Where to buy Best Gaskets here: > http://www.bestgasket.com/distributors.asp
I don't worry about external corrosion of the intake manifold or heads....
Are they truly polished (like chrome) . . . or just glass beaded? If truly polished, then it is tough. I'm currently looking into clear ceramic coatings (as used in wheels). Drop me a PM if you are interested.
Dale
Bored-&-stroked
Does the clear ceramic turn "White" when exposed to heat???? I know if you if you shoot them with straight clear...it turns a funky whitish, greyish, greenish color.
sir-Thank you much for your information-I have ordered the items. If I am able to ever help you- just ask. Best regards Bob ( T bones)
