rotorwrench
The 7.1/7.2-volt comes straight from the Lincoln Mercury Overhaul manual for the 1949 thru 1951 Lincolns & Mercury cars.
Post Script: I went back and checked and I was wrong about the voltage. The voltage limiter setting is from 7.2 to 7.6-volts at ambient temps between 70 & 80 degrees F. The generator is rated at 7-volts but the regulator setting always falls in a range depending on conditions.
